TwinTurbo.NET: Nissan 300ZX forum - Re: Are you doing any machine work to the block?
DanielThomas
on August 09, 2020 at 2:48 PM
posted by Doug71zt(CAN)
on August 07, 2020 at 03:58 PM
So far just ported the water passages, i may get them to shave a bit off the block just to make sure its totally flat. If the machine shop remove the valves and jets, do i simply buy more and they press fit back in?
How to change block oil galley & brass plugs?
DanielThomas
10:15:13 08/06/20
Re: How to change block oil galley & brass plugs?
DanielThomas
10:40:01 08/06/20
I drill them, tap them and screw a bolt in to slide-hammer
Doug71zt(CAN)
09:12:53 08/07/20
Don't forget the check valves and jets at the deck surface. (n/m)
Doug71zt(CAN)
09:14:14 08/07/20
DanielThomas
11:32:15 08/07/20
Doug71zt(CAN)
15:58:20 08/07/20
DanielThomas
12:35:59 08/09/20
Re: Are you doing any machine work to the block? -
DanielThomas
14:48:50 08/09/20
Yes, just knock new ones in with a punch.
Doug71zt(CAN)
11:23:48 08/10/20
Part Numbers
Doug71zt(CAN)
11:28:49 08/10/20
